Ajventura2
- 0
- 0
- Ypsilanti, Mi
It seems as though my M1008 isn't charging correctly on the Gen1 side. The gen2 side is charging great and the back battery is getting plenty of voltage. However, the drivers side alternator is not putting out and charging the front battery. The gen1 light on my dash has never worked so I am not sure if it is a wiring issue or the actual alternator. From my understanding, the 2 wire plug on the alternator, the red wire is always hot 12v and the brown one is suppose to be hot only when the key is turned on. Well the brown one does not go hot with the key turned on. I really do not feel like tracking down that wire and trying to figure out why it is not getting hot, but is there a way to bypass the whole system and just tie that brown wire into another system that only turns on with the key? Thanks.
