Alternator Wiring
Sorry to be a pain in the rear about the same old stuff. On my passinger side altinator i have a red wire and with it is a little red wire. I also have another red wire that the hole is smaller than the pos post on the alt. The other post on the alt looks like a ground post. then i have the plug with 2 wires that is pluged in. it seems to be charging by the gauge. the 2 alt light does not come on. I dont know if it makes a differense or not. But where does that other red wire go. everything is all stock. I serched the tms. for 1/2 an hour looking. thanks for the help.
Warthog
236
OKC, OK
I don't think a Deuce wiring diagram will work on a CUCV. :wink:
When reading the CUCV diagram, you have to look at mulitply diagrams. The ones you need are E-09 and E-11 from the appendix from the TM 9-2320-289-34 tech manual
The Red wire with the white stripe is the 12v feed to the "isolated ground" post on the passenger alternator. This allows the two alternators to combine for 24.
The large Red wire on the positive terminal is the 24v output.
The small red wire is really orange. It is the 24v putput sense wire for the STE/ICE diagnostic system. Not need in everyday life.
The two pin plug wire is used for the alternator excitors system. If this plug is dirty, corroded, not pluged in, your alternator will never work.
Read the stickies for more details
glassk
Hampton, GA
Saw a post about Clear Titles and of course I made the mistake to add something about Part numbers would Be help ful,...
just my Two cents , New poster , Poor spelling, asking the same thing, wonder if he can tell you the First seven of the VIN,......
