Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Valve stem is in the wrong spot, would have to drill and install the ctis valve stem. Hole in the flange is already in the right spot. Would have dual valve stems.
If you look at the rim itself, the valve stem is in the same position as the steel rim. The stem is directly across from the hollow supply stud. The CTIS wheel valve is the same on these, the only difference being the change in the fitting that attaches to the stem itself. That changed in models after 2007.
pre 2007 steel rim 2007 and later steel rim 2007 and later aluminium rim
