AMMPS MEP-1040 10KW Generator List of Part Numbers
Daybreak
2 Star Admiral
769
Va
AMMPS MEP-1040 10KW Generator Parts
MEP-1040 10kw AMMPS Generator 6115-01-561-7455
YANMAR 3TNV84T-BMCU engine (3 cylinder turbo, 1.5L)
Air filter
Fleetguard AF26168, Napa 9168, Wix 49168, Baldwin RS5325, Donaldson P616641
Fuel/Water Separator
Racor R15S, Napa 3433, Baldwin BF46019-O
Oil Filter
Yanmar 119005-35100, Napa 1344, Baldwin B161-S, Fleetguard LF16157
Oil
Good 15w-40 heavy duty diesel oil
Coolant
Good heavy duty coolant
Belt
Gates ax38 9012-2038 BELT, v drive 1/2 inch x 39.3in alternator
Fuel pump
Airtex E11025
Fuel Level Switch
FSCMN-01 fuel level
coolant 6.2 qt (radiator and overflow 4 qts, block 2.2 qts)
oil 15w-40 diesel oil 5.9 qt
fuel tank 6.3 gallons
Batteries
2 x Optima Yellowtop 51R
Panel Rivnuts
39101-76030, AVDEL, EURO HEXSERT 39101 INSERT M6
The AMMPS units use a lot of commonality of parts.
mciikurzroot
232
wimberley texas
Bingo !! we have a winner, perfect timing, Thanx Daybreak, im just back from NAPPA with the 1344 oil filter and will spin it on and see how my water temp situation goes, after more reading the -24 im leaning hard to the T'stat not opening till much later than desired, and PWM cooling fan might have issues, time will produce the core problem and a answer as well, fortunately cooling issues are typically easily solved.. Thanx so m uch for the reply and solid info .. mac/mc
Hmvpartsupply
Vancouver wa
I have a unit with a brand new engine and everything in it it was dropped on the side and they rob the control unit off of it but I’m going to be putting it out if anybody’s interested in parts
Guyfang
23,946
Burgkunstadt, Germany
Same suggestion here. Put the info in a spreadsheet and lock it. We can make it a sticky. When you want to update it, unlock it, and fix things. Relock it.
Jasonrs4317
14
Concord nc
I need some help with my Mep 1040. Batteries are charged but I am not getting the control panel to come alive. Trying to trace the electrical path to hopefully find a fault. Any help would be appreciated.
Guyfang
23,946
Jason, what you need to do is start your own thread. Call it "MEP-1040, wont start" or something like that. This thread is about part numbers. Your getting help in this thread is slim and none. And slim left town. If you need help starting a thread, say something and we will help you.
CallMeColt
1,474
Wilson County, Texas
Anybody come up with a nice list for the body hardware like the TQG's? I just got one of these finally & it's I need of some. They're pretty specific. If not, I will figure it out eventually.
