dabtl
- 7
- 38
- Denton, Texas
I have had two exact duplicate bearing mounts made. More can be made.
This came from an original bearing mount bracket as a pattern.
I have a close to original bearing bracket shield. I need an original to compare and build from. If you have one that I can borrow for a couple of weeks, it will be a nice pattern. If not I will assemble the one I have and check measurements to make sure it will work.
I have ten under cab brackets and J-bolts coming fairly shortly.
The pillow bearing and U-Joints are easily obtained from commercial suppliers.
The long drive shaft is available quiet cheaply. I will have the measurements for the short drive shaft and possible conversion of the long shaft to fit soon.
Looking good for a change. I am sure glad to be out of trials for a while!!!
