angry at my Cucv
1,808
I would also consider the current fuels and rebuilders. Todays fuel is very dry. Stanadyne is probably compensating for this with updated rebuild kits but I'd think many rebuilders are using up old stock first. Try adding a lubricity formula.
rchalmers3
30
Irmo, South Carolina
I'm not a chemist nor do I play one on TV, but I believe the sulphur removed from diesel is what used to act as a lubricant.
rick
zout
154
Columbus Georgia
Cucvnut - if you allow mechanical items to get the best of you - you are defeated before you begin.
Its man made - it can take a crap whenever it wants to - that means even if you had just pulled it off the showroom floor from a dealer - MURPHY.
You could be doing the best you can on PM's - inspections or whatever - and the most unlikely item will be the thing to break or fail on you - MURPHY
Stand back - take a deep breath and look at it from a different perspective - you cannot allow this stuff to run you or manipulate you - Holy Cow - its just mechanical stuff that man invented to frustrate us in the first place.
You can do it Bro - just get a grip.
4,794
You sure it's not an electrical problem? That one pump that was on your truck is still running fine in mine (after I replaced the solenoid). Do you still have a 24v setup? Maybe there's something funky with your wiring causing a higher than normal voltage?
Cucvnut
61
Carver, Oregon
I did not count that pump since it runs on your truck. :)
zout
154
Columbus Georgia
CUCV - do you know what volume of fuel is actually going though the system or was it pre-set when you got it @fuel pump and what was the pressure set at ?
Is there a pressure regulator in the system - is there an actual read out of what that pressure is ? A physical reading heading into the pump ?
4,794
Well it didn't run at first, I had to swap a solenoid as the one on it was smoked. That's why I put it out there that maybe its somehow getting 24v? I dunno, I'm just grasping at this point.
