Thanks lacoda56, all steel is 3/8's plate so far.
No.2Diesel, You werent kidding about 20 questions!
The armor is pretty close on the actual thickness. Armor on these were 6-12.5 mm.
So for us here in the states, 1/4 to 1/2 inch will work.
Tatra and Praga are the Czech version. Hannomag and Bussing-NAG made the german half tracks.
Off road they do well, havent had a chance to try one against the other. They do tend to "push" while turning on pavement, and in the soft terrain you need to kind of feel during turning and using the steering brakes so the the tires dont take too much abuse.
Hard to explain, but you can feel when the track is turning smoothly.
The tranny is a 4 speed with 1 reverse and a hi-lo. And suspension is torsion bar. Never really had a problem overheating as long as the fan works.
The welder is a miller 220v unit burning .045 wire on the bottle. Not sure the model, but its big.
Not sure on the history, but maybe could find out, I'll ask the owner when I see him.
I'll see if I can get the brand off the tires for you and report back.
Did you mean detailed drawings for the track? If so search online, we found a couple, allthough you will probly have to convert them over from metric(no big deal).
Thanks guys,
Mark
