Another Dead short
dstang97
30
Clover, SC
Now i have one in my drivers side alternator. This is not making sense. Advanced auto said it tested good. But when i have the wires hooked up and a test light from the negative to the battery it is still lighting up. What is weird is its not enough to pop a fuseable link.... So what gives? when i disconnect the wires the test light goes away. I am 99.9% sure it is not a cut in the wire.
That last short i had was a bad starter, but is fixed now.
HikerMan
Boise, Idaho
One short I had that was keeping my truck from starting for awhile was a melted, grounded diode behind the air cleaner that made the short on and off, confusing the **** out of me. Not sure if this will help, but good luck :beer:
dstang97
30
Clover, SC
I'm going to swap out another used alternator and see what happens. I do not trust the people down at advanced auto. I will report back later on in the day.
1,174
I've read many posts here, where people say the auto store tested their alt and said it was "good", when in fact it has had a bad diode or regulator, causing a slow draw/short.
