Another deuce brake problem!
WillWagner
3,205
Monrovia, Ca.
My brake lights stopped working today. The switch is still at the end of the air pak. I am having CRS real bad today, I know....no, think.... there is a MWO to move the switch, but I can't find it. Again, TMI for this stuff, i'm starting to get it confused with work! Anyone know where it might be located and who to get the parts from? I also have a NO swich for a converter lock out for an Allison trans.The stuff I used it on was 12VDC. Will it work on the 24 VDC system? It is basically just a set of contacts, right?
ah1955
Lancaster County Pa.
You are right about moving the switch, I don't remember which way is which but I know it has been covered somewere??
There is also a post somewere that explained how someone mounted a lever type auto brake light switch with a bracket at the brake pedal, don't remember who(would be nice to give them there due)
Sorry not alot of help with details but might help getting you on the right track.
m-35tom
229
eldersburg maryland
RE: Another deuce brake problem
the brake light switch is just a NO pressure switch, but it is the pressure rating i would wonder about. civ switches will work just fine, but the pins are just off a little and they don't have the boot. oem mil switches are cheap, why not just get a new one??
lacoda56
Rochester, Washington
If you lose air, your brakes won't work, so what's the difference at that point if your brake lights are are inoperative? It's an upgrade 'cause it's working under low pressure and less prone to failure.
WillWagner
3,205
Monrovia, Ca.
I didn't check the Saturn site. I'm all over it! lacoda, the brakes still work w/o air, just not like "power" brakes...no boost. Coulda sworn it was a MWO. Thanks guys.
Boatcarpenter
Marlborough, NH
The hydraulic side of the system will still work I believe, you just have to push harder on the pedal. Get in your truck and step on the brakes with no air pressure, you still have pedal and you can stop the truck from rolling.
lacoda56
Been there, done that, and the truck without air don't stop worth a da**. Try it if you don't believe me! As I said, no brake lights at that point are the least of your problems.
gbooth
14
Heartland,
Will My brakes lights quit not long after I got the truck running had power to the switch just wasn't going through replaced it with the kit from Saturn it is now on the air side it works fine I left the old one in the hole it is just acting as a plug. When I wired trailer brakes up for the truck I went down to the local TRUCK parts store bought a unisveral brake switch to power the brake controller this switch look just like the up-grade switch from Saturn, You can by one local, add a " T " fitting and it will work just like the up-grade switch, all fittings were got at the local hardware store.
Boatcarpenter
Marlborough, NH
Maybe it won't stop worth a da**, but my point was that you will still have brake lights to at least indicate that you are trying to stop.
cranetruck
94
Meadows of Dan, Virginia
BC is correct.
Like Tom suggests, watch the pressure rating of the switch in its original application. It will normally be exposed to 1,800 to 2,000 psi and should have a rating of twice that.
I prefer the original location, just get a switch that's up to the job.
The procedure is shown in PS magazine (don't forget to do a search here when you have a question).
m139h2otruck
NH
Ask John Tennis what happens when the old style switch develops a leak!! Brake fluid on hot exhaust parts is not good. Needless to say, he changes all of his to the newer air style.
