Screamer27
- 1
- 0
- Des Moines / Iowa
Yes I searched, for over 2 hours now reading post after post and found some very valuable info. I have done some diagnosing, and still coming up blank.
Over the last month the m1009 has been getting ALOT harder to start. Finally yesterday, It spins over fine, but just won't hit. If I go from the tip of each glow plug to ground, I have OL on the meter, meaning all of the glow plugs are dead. If I go to the wire terminals going to the plugs, and key on I get 24 volts for about a second, then I have 1 volt for 3 seconds, the relay keeps cycling about 3 times while the wait light is on, yet keeps cycling with the key on, but the wait light out indefinitely. If I jump the blue wire to ground from the relay, I have constant 24v at each glow plug. I relize all of the glow plugs are bad, but I want to fix any other issues before I blow 100 bucks on glow plugs, and have them all blow instantly. The wait light seems to be working fine,
