m56-mike
- 1
- 3
- Northwest Iowa
Hello all it’s been years since posting. I’m seeing some similar posts but none quite like my issue forgive me if I’m covering old ground. 2009 MMMWV 6.5 turbo 4 speed Truck 480 L no shift. Unit was sitting for god only knows how long. Ex marine corps unit
So
my trans is in second. Trying to shift one two or anywhere does nothing. Converter feels like it’s never quite locked up. Real mushy 30MPH engine screaming. Fluid levels all good. I changed my TPS at the urging of a hummer guy. No change. Messed with and tweaked adjustment on tps. No change.
So as suggested I jumped post A-E on the trans control module to “count the blinks” but I have none. In fact usually in other units, I thought you always got a quick trans light flash when starting. I have none. Ever. Including with the pins jumped.
I then took the 472 pin connector loose to my trans control module. I checked every pin for power. Both with the ignition on as well as with it off. No dc voltage anywhere. Shouldn’t something there be live? I then started looking behind the batt box. I found a resetting breaker that seems to have no power with the unit turned on or off. At least the top lug I could get too. I can see the trans relay nut getting to it involves more tearing apart and I was loosing light.
I think we have no DC to this trans& trans controls.
thoughts?
thanks Mike
So
thoughts?
thanks Mike
