SteveH
- 4
- 8
- Connecticut
Thanks to all the advice posted here (especially sewerzuk), got my MEP-003a autostarting yesterday (worked first time!!)
I'm using a Unitronics Vision230 PLC, and interposing relays (the relays aren't really needed, as the PLC has onboard relays, but I used them for additional protection, and the LEDs give an indication of the output and input status. The Vision230 is overkill for this application, but I got a great price on ebay. The code will run on their smaller units. I also hope to be able to monitor volts/frequency/load using Analog Inputs and the ethernet port (with a remote web based app), but that's not done yet.
At this point everything is laid out on a piece of plywood for test, but the plan is to put it in a small NEMA enclosure with a UPS. Start will occur on closed contacts from a standard domestic auto transfer switch.
I will be posting more info (especially connection diagrams) once the project is completed, but for now just wanted to share a video of it's second start..
http://www.youtube.com/watch?v=SVqjAAfHoS8
Again - Thanks to everyone for their help so far with this!
-Steve
-Steve
