talskinyguy
- 0
- 0
- DeKalb, IL
I wanted a muffler on my M35A2 because its just too **** loud. Talking to a passenger is impossible and my ears hurt for a while after a long drive.
I wanted 2 things:
1. The most sound reduction possible
2. Not adding additional restriction to the exhaust. From what I have read the engine flows around 400-450cfm.
Looking at mufflers most people here are using a small bullet style muffler, and I wanted more. One person said they are using a Donaldson M070025 which has the following relevant stats.
719 CFM is far more than I need, so I kept looking and found this. The Donaldson M090146 which has the following relevant stats
That is still at least 30% more flow than I need a the lowest pressure difference it is rated at of 1 In Hg, which is about 0.5 psi. That is the muffler I chose and it just arrived today. Here it is.
![1526642_10151875960060823_256804241_n.jpg 1526642_10151875960060823_256804241_n.jpg](https://www.steelsoldiers.com/data/attachments/322/322141-31a1f947e75337f9ca00ab03ef5c191c.jpg)
It is worth noting that there are cheaper and more expensive mufflers that cross reference with this muffler, but every since one of them I could find a review of said they were a straight through muffler that you could look right through. This muffler is not a straight through muffler and therefore should have a better sound reduction. The do fit all the physical dimensions of this muffler but they are not the same. I picked this up on ebay for $135 shipped.
More posts to follow as I install it. This will nearly completely replace my stack starting from about 3-5 inches above my fender.
I wanted 2 things:
Inlet Diameter: | 3.50 Inches (89 MM) |
Outlet Diameter: | 3.50 Inches (89 MM) |
Body Diameter: | 7.00 Inches (178 MM) |
Body Length: | 14.00 Inches (356 MM) |
Overall Length: | 19.75 Inches (502 MM) |
Rated Flow @ 1 In hg | 719.00 CFM (50.80 CMM) |
Attenuation: | 10-15 dBA |
Inlet Diameter: | 3.50 Inches (88.90 MM) |
Outlet Diameter: | 3.50 Inches (88.90 MM) |
Body Diameter: | 9.00 Inches (228.60 MM) |
Body Length: | 44.50 Inches (1130.30 MM) |
Overall Length: | 51.00 Inches (1295.40 MM) |
Rated Flow @ 1 In Hg: | 578.00 CFM (16.3574 CMM) |
Attenuation: | 19-25 dBA |
