Olly
- 7
- 18
- Bristol/CT
What size wrench do I need for the bolt that holds the flange on? My adjustable won't fit in there and none of my wrenches or ratchets are the right size anyone have any idea?
Did you get a new seal? You are gonna need 1 or 3. They are the same seals for the pinion on the 5 ton Rockwell's so it's good to keep alot around. Checkerboard farms on Ebay has military seals for cheap. Best to buy 6 or so to have on hand.Thanks again for the quick responses and great advice Simp I really appreciate it
Hey, is the part number for this seal: 500177? I just wanted to make sure I was looking for the right one. I went to look at Checkerboard and they must be out of them or I'm searching the wrong number because I didn't see them... so I just wanted to make sure I was searching the right seal. Thanks againDid you get a new seal? You are gonna need 1 or 3. They are the same seals for the pinion on the 5 ton Rockwell's so it's good to keep alot around. Checkerboard farms on Ebay has military seals for cheap. Best to buy 6 or so to have on hand.
[h=2][/h] |
[h=2][/h] |
Use # 12470105. He has them for $9 each.Hey, is the part number for this seal: 500177? I just wanted to make sure I was looking for the right one. I went to look at Checkerboard and they must be out of them or I'm searching the wrong number because I didn't see them... so I just wanted to make sure I was searching the right seal. Thanks again
[h=2][/h]
[h=2][/h]
