jimm1009
- 70
- 48
- Louisville, KY
Has anyone ever purchased a torque stick extension that is rated for the correct lug nut torque.
By extension, I mean the same type of extension that would be used between a normal socket wrench and socket to extend the hight for reaching into a deeper area to loosen or tighten a nut or bolt.
The reason I ask is that there are torque sticks that are available for the outer & front lug nut but not the inner rear nut (that I know of).
A guy could use the standard budd wheel socket with a torque stick extension
had then have the best of both.
If you have come across this tool or know of one that will work (brand name)for both lug nuts please let me know.
jimm1009
jimm1009@yahoo.com
jimm1009
jimm1009@yahoo.com
