Another Torch Kit Info Needed
CARNAC
The Envelope Please.
619
Corpus Christi, TX
My second frustration and this one may not have a resolution. BTW, been working this issue for over a month.
Looking for the NSN's for the components of the Soldering Torch Kit.
3439-00-542-0531 B X U EA 1 1
TORCH KIT,SOLDERING, C/O DISPOSABLE FUEL CYL,BURNER UNIT, PENCIL BURNER HD, UTILITY BURNER HD, SOLDERINGTIP,FLAMESPREADER,FLINT LIGHTER,PLASTIC OR METAL CASE
The flint and spark igniter are based on the other torch kit so may not be correct. The propane refill cylinder is correct. If anyone has any info....I again tried all the usual sources. Looking for the NSN's and the model numbers are posted.
6830-00-584-3041* C* X* U* *EA* 1* 1 PROPANE, GAS REFILL CYL, 2-3/4 IN. DIA, 10 IN. LG 26.7 FLUID OZ FUEL*
UL2317 C* X* U* *EA* 1* 1 PENCIL FLAME JET TORCH
810 C* X* U* *EA* 1* 1 FLAME SPREADER
tx405 C* X* U* *EA* 1* 1 5120-00-965-0326 SPARK/FLINT LIGHTER
TX406 C X U EA 1 1 5120-00-965-0603 FLINT RENEWALS
C* X* U* *EA* 1* 1 CASE, CARRYING
650 C* X* U* *EA* 1* 1 UTILITY FLAME HEAD
JT869 C* X* U* *EA* 1* 1 SOLDERING TIP
Chief_919
100
Western NC
Are you looking for NSN's or just the parts? If memory serves me some of those torch kits never got NSN's for components, and you had to order parts using part number and CAGE.
CARNAC
619
Corpus Christi, TX
Dang Chief, you made me choke on my drink. Sorry to disagree but my experience with the Grainger NSN cross reference has been so inaccurate I just don't even go there no more.
I do concur that I'm probably hosed for NSNs and that I'll have to be stuck with part numbers for this torch set. Figured it was worth a shot though.
