1984 M1009 stock
Hey guys and gals,
So I have been on here reading for a while and decided to run this by you for a second opinion.
I noticed a few weeks ago that when I would start up and start to pull off sometimes it would take a second for the tranny to catch up with the throttle, so to speak. It would not move for a second, and then it seemed fine.
Well today driving home I noticed that the engine appeared to be running at a higher RPM to keep up with normal driving speed, 55 mph. It was like the tranny was not keeping up with the engine. Dang this is not good. I also noticed that it seems worse that faster you are going. Not as bad rolling in first gear.
So I ran by my mechanic to get his opinion. I know him very well and trust him but it is still pricey having a shop work on anything. So I explained everything to him, we checked the fluid levels, full, clean looking, and no odd smell. We went for a drive and he agreed that it was not right. He thinks that I need a rebuild. That the issue is the clutch going out. This an expensive option if I let him do it.
Could there be a simpler explanation? I have the manuals but have not had a chance to look at the trouble shooting yet. That will be first thing in the morning. I have been on here reading / researching but most of the post are about not shifting, hard shifting, or slipping. I don't feel like mine is slipping and it shifts, but you have to run the engine harder than you normally do to keep up your speed.
So what do you think?
Hey guys and gals,
