antenna mount and bracket
Manstein
Chaplain Emeritus
331
Cartersville Ga.
I need the box looking antenna mount spacer and the scoop looking mount. If you have one or you know where to find one please tell me. I check with Saturn and Memphis... nothing.(drats and double drats)
CGarbee
552
Raleigh, NC
I have a sketch of the SC-C-189025 standoff bracket used between a scoop mount and the bed side of a M37 or M35 when mounting the MX6707 antenna base. Bracket is used in order to prevent the base and antenna from contacting the bed side (especially the upper bed edge). The sketch is on my website (dimensioned) for use in fabricating one of these brackets if you can't locate one easily for sale.
Drawing is located on my MWO/TB page at:
http://www.garbee.net/~cabell/mwo.htm
Good luck.
