- 2,960
- 30
- 48
- Tiro, Ohio
Thanks to JasonS for sending this my way.
1962 white semi tractor with(I was told) reo 400 ci/200hp engine.
Can anyone verify this is the reo 400ci/200 hp engine? Tag on door say 6/200 AC2 for engine code.
Wanting to rebuild this and replace the 331 in the M108 crane truck. 331 is running on 3-4 cylinders. Figure this way the 19,000 lb truck would move better. I think, from what I've read, engine is a bolt-in replacement. Would keep the 331 in case next owner would want original engine.
Can anyone say what is involved in changing to the bigger engine?
Any guesses to weight of truck? Hoping it's under 12,000 lbs, then I can haul it with a trailer. Gas engine, one rear axle, no transfer case, and lighter beam axle in front. Should be much less than a standard 13,000 deuce.
Looks like this thread has some good info.
http://www.steelsoldiers.com/index....=0&postdays=0&postorder=asc&highlight=reo+200
Seems JasonS know the engines pretty well.
Dennis
Dennis
