NovacaineFix
- 1
- 18
- San Diego, California
This may sound weird or strange but I figure I would ask.
I just wanted to inspect my clutch on my 818 to see if it is worn down or if it is just a pedal adjustment or whatever.
Before anyone tells me to read the TM, I have. I have removed the 6 bolts and looked into the inspection cover but all I can see is the pressure plate and a grease fitting for the throw-out bearing that has probably not been greased in some time. More on that later.
The only other way, besides taking the trans out, to see the clutch disc I think is possibly removing the starter. I may be able to see the edge of the clutch disc and determine how much of it is left.
The reason?
I wanted to take my 818 on a field trip, round trip is about 350 miles, but I noticed the clutch seems to be grabbing at the very top when releasing the pedal. I know this could be an adjustment, but I was curious to know if there is any other way to see the disc without removing the trans. I even stuck a remote fiber-optic camera up the inspection window, but I cannot make the turn beyond the throwout bearing to see the disc.
Everything is running fine, clutch works, just high on the pedal, no problems, but I don't want to assume and have a clutch go out on my trip if I can help it
Okay, now about the throwout bearing.
Does anyone know what combination of fittings are required to grease the throwout bearing?
I can see it and feel it, but every combination of fitting and adapter I have seems to be either offset by the throwout shaft or the edge of the pressure plate. I was thinking a straight tubing piece that comes with most grease guns would work, but then it's up against the crossmember.
Any ideas?
Sorry for the lost post, the result of having too many adult beverages and internet surfing, ha ha.
The reason?
Any ideas?
