Any ideas on relocating intake canister and exaust pipe
chucky
18,961
TN .
I was wanting to relocate breather can to draw air from side of truck without being above bulkhead wall of bed and to move exaust pipe out from behind battery box so i can place tool/ generator box between batteries and tire . i have already removed spare tire rack my camper box will just clear bulkhead wall and go to back of cab Ifigured someone on SShas already compleared rhis task thanks
chucky
18,961
TN .
OH thats an awsome thread !!! lots of great ideas .Thanks
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
You can contact member GimpyRobb if you need an air cleaner assembly. he probably has about 5000 of them in the Beefco Warehouse in Ohio.
Jbulach
2,184
Sunman Indiana
Yep, if your doing a setup similar to profo, the air cleaners gimpy has would be even better than the m939 unit. Almost a direct replacement with the exception of 6” in and outlets, instead of 5”, they also seal better, flow a lot more, elements are a ton cheaper, and open easier. I’m going to put one on my 5 ton eventually. Let me know if you work something out with him, I could probably hand a couple off near Nashville around the end of March.
