Any Pictures of Deuce Led Lights?
862
Reading Pa
I'm looking for pictures with trucks that have led conversions, not head lights (I found dozens of threads on head lights) but the turn signals and marker lights. I only found a couple but I was wondering how many other guys out there have them swapped out and how they like them. Pictures at night and day would be great!
Thanks Dan
welldigger
15
Benton LA
I loathe the led turn signals and tail lights. Yes, they are wonderfully bright, but they burn out. By burn out I mean totally die. Bad grounds kill these things so fast. In my opinion your money and time ahead if you just put led bulbs in the incandescent housing. That way if one craps out just replace the bulb instead of the entire fixture.
1,125
I like the LEDs in that they are really bright.
However, when they burn out they're done. Lot more expensive than a bulb.
The other downside is that the taillights (not sure about the front turn signals) aren't as visible if you're looking at them from an angle. If you're directly behind them, they're extremely visible. But if you're at an angle, they aren't nearly as visible as the standard incandescents.
taylordc15
Sale Creek, TN
Tagged for updates. I have the factory LED's and as others have mentioned mine burned out after about a year. Interested in what LED bulbs you end up putting in the factory housing
