SGT Estum
- 0
- 0
- Twin Cities, MN
I'm in the market for an impact wrench and having a hard time deciding on which one to buy. Wondering if anyone here has one they use and would recommend.
I realize there's a full range of products out there ranging from cheap Chinese crap to Ingersoll Rand. So, to frame it up a bit, here's what I've got in mind:
I posted this in the CUCV section because I'll be using the tool on my M1009 and similar sized equipment. There're lots of impact wrench threads on The Deuce forum but those guys are all talking 3/4" or 1" drive units which is a bit more than I need.
Any thoughts welcome!
- Made in USA, if at all possible.
- Affordable - this will be used mostly for tire lugs in my not-professional garage. Under $100 would be nice.
- Capable of removing lug nuts torqued on to 150 ft/lbs
- Able to run off of my 30 gallon air compressor that produces 6.2 SCFM @ 40 PSI, 5.3 SCFM @ 90 PSI
