Anybody tried these wheel balancers?
SausageGuy
35
Kansas City MO
Just found these for big rigs. centramatic balancers
Any thoughts? The hole pattern can be changed to match our trucks no problem. Up to 16oz of balancing of beads which is what I put in front tires.
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
They make them in budd and hub pilot. They make them different for steer and drives. They are only designed for 8.5in wheels. They make one for a 9in and wider for aluminum wheels.
They do not make them for steel wheels wider than 8.5in so they would not work with the 20x10 combat wheels. Super single budd wheels aren't common in the trucking industry as everything has gone to hubb pilot.
Charts say 16oz for big tires but not totally accurate. This is a spin balancing on a 445 65 22.5 that is Slightly shorter but wider than a 395. It only took 3oz
4,815
I haven't used those. But I use the beads you install inside the tires in several of my vehicles.
ckouba
1,724
Oregon
Who did that for you? Are they a national chain? Would love to get mine dynamically balanced. I'm near Portland, OR and no one I've called has the capacity to do this.
simp5782
9,369
Mason, TN
Local place called unbeatable tire
Some T A truck stops have a dynamic balancer in their shops
Curtisje
693
Okinawa, Japan
I use Centramatics on my 2 CUCV's. They work well for me but my tires are quite small compared to yours. 37x12.5R16.5
