dakotafear3088
- 0
- 6
- Danville pa
Just curious if anyone has seen fuel residue or droplets comming out the air intake mantifold tube... part located with the cold start unit? first off the cold start unit is removed and NO fuel lines hooked up... so that idea is out the window...
I noticed this while running the truck for several days and running highway speeds, so im not sure if this is too much fuel and its being pushed back out the intake matifold, or could this be a stuck or broken valve that is causing this problem? the truck is not turned up and has stock everything, so im trying to put pieces together of internal problems or something minor. If anyone has seen this or has this please let me know as im wondering if this is a "normal' thing for these multi's. Any input and or ideas would be greatly appreciated.
