Anyone familiar with power distribution box on M1083
chucky
18,858
TN .
Question for the electrical gurus on here know if we can do away with this box and bolt the cables directly to each other { from same post of coarse} I was cleaning the 4 post on mine today and got to the bottom of the 4th stud takeing the nut off with a 4 in long 1/4 in ratchet and not even hard to turn and BAM i snap off the stud off flush at the box ! Does anyone know which stud does what on the box from top to bottom? What to do can i just bolt those 2 cables togeather and leave the others conected to the dist box or just remove the box??????
NDT
6,261
Camp Wood/LC, TX
The consensus here is it’s ok to get rid of or bypass the polarity protection device. Just don’t make a mistake if you jump it off because lots of expensive stuff will go poof.
There are 4 terminals, 2 are 12 volt in and out, the other 2 are 24 volt in and out. Most people do just like you say, double lug the appropriate cables together on one stud.
chucky
18,858
TN .
Thanks i was just reading one of your replys on this same subject , Since it was the bottom lug i will just move those 2 cables up to the next lug which i beleave thats all 12 volt i was going to put a meter on it in the morning to double check !! Ronmar i think it was not sure i read a bunch had said i could get a 150 amp fuse and put it between the good and bad post .
