I think everyone is missing something. I already have a solar system and want to supplement my power when I switch more over to electric. I have a 43 panel system that is already grid tied (no batteries) with a title II power generating certificate. I am asking for the safest way to keep my bill at zero using a cogen system to offset my electric costs while producing heat for the house and garage. My consideration of a power inverter that is certified for a grid tie is the most expensive option hence why I am asking for other suggestions. I am not going to just willy nilly plug this in. I am asking questions if someone has done this before and best methods and practices. I appreciate all the cautions and that is why I am asking for help to consider all factors.
See post #4.
You cannot generate power from a fuel burning generator cheaper than you can buy it from the grid.
Fuel, set up costs for various devices, maintenance, etc. Its false economy no matter how you slice it.
Fuel ranges from $2.40 to $2.89 per gallon. At 1 gallon per hour(conservatively) that's $25.00 to $30.00 for ten hours running time.
Add in your labor to keep the set fueled, possible failure/breakage of parts, on and on.
Generators are meant for alternate power sources when the grid goes down, and primary power sources where grid power is not available, not grid supplementation. Having a solar setup where there are rebates, financing and power from the sun is a whole different ball game.
If my power company was raking me that bad on power prices, I'd go off grid in a heartbeat and be done with it.
I had three poles with the primary lines run into my property with two service drop transformers, both 400amp services and it didn't cost me a penny. I called for power on a Thursday afternoon and 0800 Monday morning the pole and over head crews were pulling in my driveway. They were here and gone in 3 hours.
My electric rates are the cheapest I've ever encountered in my life. So until the rates rise beyond what I can generate my own for, I'll stay connected. My generator is for the possibility of a long term power outage, what ever the cause may be.
You can't make power cheaper than the power company using a generator.
