Anyone have a bad alternator? I need parts.
ida34
33
Dexter, MI
I had a problem with one alt not charging. It was alt 2. I tore it apart and found the output stud loose. I found that the listed metal link had burned away by the excessive resistance and heat. I now need a new stud with nut, the insulating washer on the inside of the case, and the metal link pictured below. Does anyone have one that is bad that I could use for these items? The rest of my alt is in good shape except for the link and stud.
Chuck
ida34
33
Dexter, MI
The insulator in the picture is not the one I need. I need the one that is inside the case. It looks like it is fiber.
ida34
33
Dexter, MI
I almost forgot. It is the 100 amp 12 volt isolated ground alt. Not the 28 volt found on some of the other cucv's. Mine is an M1009.
