Anyone have a picture of how the rear axles on a deuce locate to the rocker beams?
R Racing
St. Leonard, MD
Anyone have a picture of how the rear axles on a deuce locate to the rocker beams? have a weird idea. but without tearing into how my rears are mounted. I thought someone may have some pictures?
Flyingvan911
158
Kansas City, MO
I don't have pics at the moment but there are four dogbones on the right and two on the left. On the right each axle has one for the top and one for the bottom. On the left each axle has one dogbone on the bottom.
R Racing
St. Leonard, MD
That's what I was afraid off. Had this stupid idea that the axles sat on a arm that located them with the links. Ultimately if they sat on a arm boss, I was going to try and make offset plates to move the axles farther apart for 1400s on my m35a3. I believe I'm barking up the wrong tree now . But sometimes neat things come from weird ideas. LOL
Flyingvan911
158
Kansas City, MO
The leaf springs are attached to the trunion in the middle (between the axles) but sit free on top of each axle. The dogbones maintain the spacing.
welldigger
15
Benton LA
Actually what you are thinking of has been done. It will require custom torque rods that have been lengthed and take a 5 ton spring pack with a few of the leaves removed. You may also need to relocate the fuel tank. I know you do with 16.00s. Not sure with 14.00s.
gringeltaube
Staff Member
2,472
Montevideo/Uruguay
I have seen it done, but not with 5-ton springs (those are 3" wide).
G.
