Anyone have several more circuit breakers and relays installed than manual requires?
Awesomeness
1,518
Orlando, FL
I looking at what the manual says should be installed in the Power Distribution Panel, and what is actually installed, and oh boy, what a mess. Every runs and works fine, but at the very least there are several things installed that don't seem to need to be there.
- I have a 3rd diode (top spot). Manual calls for 2.
- I have 2 extra relays installed in the top row, 1 extra in the bottom row.
- I have at least 5 extra circuit breakers installed.
Awesomeness
1,518
Orlando, FL
Most trucks I have seen have 3 diode packs installed.
I'm going to look at the wiring diagrams. When I pull that top diode out, the two right terminals (under the D3A column heading) aren't even populated in the power distribution panel. Maybe it's just a spare?
Suprman
696
Stratford/Connecticut
I think they absorb spikes. One for each voltage 12 and 24. Normally diodes like that are bridge rectifiers used to convert ac to dc. I never really thought about the fact that there are 3. The trucks seem to work ok without them. Dill Blox makes the panel I wonder if they are in all of this style panel.
Awesomeness
1,518
Orlando, FL
The standard diode function is letting current flow only one way. It's not real clear what other purposes these may serve.
I'm just going through the power distribution panel because it's clear that my truck has been serviced in the past by people who were merely guessing at how to fix it. I want to make sure what is in my panel is what is supposed to be there, and that there is nothing misplaced, incorrect, or missing. It turns out I appear to have some extra stuff, so I'm going to try taking the extras out and double-checking that everything is functioning as it should be.
Ronmar
7,451
Port angeles wa
Remember that there are a lot of variations of these trucks. The power panel was configured for all these variants. Mine had relays and circuit breakers in place for the oil cooler found on the 1088...
