Anyone Know the Length: Negative Battery Cable for Front Battery??
jplace1011
488
Santa Ana, CA
My Front Negative Battery Cable, the end that goes on the battery is stripped out. I’d like to just replace the entire negative cable. Does anyone know the length or have a link to one?
I wasn’t able to find one via Hilly Billy Wizard. They have many different ones at O’Reilys, but I don’t know the specs or which one to get exactly. I’d prefer to just leave it in there and not have to measure it. Hopefully someone knows.
Thank you for any help. I appreciate you!
ssdvc
639
CT
OK, needed to get up and walk around, so I went out and checked. I think the negative cable is between 42 and 48 inches. Due to surgery, I couldn't take anything apart to get an exact measurement, but I think that should be good for the cable.
jplace1011
488
Santa Ana, CA
Thank you for that! Be careful, I’d hate for you to get hurt doing something so simple. I don’t have the right measuring tape myself. I don’t know where my wife keeps the non metal one. Doh!
WWRD99
1,647
York Pa
My batteries are out of my blazer right now...from the best I can do with them still bolted down is 44 inches...that should be a good starting point...I got bulk cable ends and a press crimper to install the heavy round ends on them with some shrink wrap...could go a smidge longer and make them exact for how yours are run...mine do have the 2 mounts on the fender liner as well...oh and I have the 6TM batteries if that matters.
jplace1011
488
Santa Ana, CA
You guys called it right. I found this 48” 2 Gauge Cable at Auto Zone. Just have to finish it up in the morning. One of the nuts is stripped on the opposite end of the battery end.
Thanks again for the help, I deeply appreciate the input. I’ll post a photos once I’m done for anyone who might have the same issue ahead.
WWRD99
1,647
York Pa
Looking at this pic again it seems like the ground wire was going over top of the rear battery side mount...now that you're replacing it you can run it under it so it won't chaffe on that again...48 might be a little long but that's not a big deal since there's plenty of room to tuck it around the battery up front and up to the rear hook up...might want to unhook the other batteries when you go to hook it up just so you don't wrench ground the terminal.
ezgn
1,039
Lake Elsinore Ca.
I would personally recommend the military-style battery connectors. So when you have to remove your battery connections, you don't have to take it off the battery post every time. Much better.
98G
Former SSG
4,268
Agreed. The military posts and then a cable with a 3/8" lug.
Also, there's no reason not to make your cables out of something bigger and meaner than #2AWG.
The only counter argument is that the one the OP picked out is already crimped and doesn't require any special tools.
ezgn
1,039
Lake Elsinore Ca.
The only counterargument is that the one the OP picked out is already crimped and doesn't require any special tools.
I would take it back and start from scratch.
19,605
What you have is better than nothing, but that cable is a smaller diameter than the "factory" cable that belongs on that truck. I had a reliability (not charging very well) problem with one of my LMTV trucks and smaller cables. Replacing that smaller "parts house" cable with big fat juicy cables solved that charging problem...
98G
Former SSG
4,268
I just did a similar thing on my pickup truck. I added the military type post connectors and replaced the cables with the 3/0 ungodly heavy cable. The goal is this is the last time I ever have to tamper with it.
I play with cables regularly. If I were going to replace battery cables on a CUCV, I'd use 2/0 or 3/0 copper cable and replace every cable that touches a battery and use the milspec post connectors. Everything would terminate in 3/8" lugs, and heatshrink would be applied to prevent cable corrosion.
The thing is, to do it right you need a heat gun and a hydraulic crimping tool with the appropriate dies. The #2 awg "parts house" cable with the factory terminal clamp properly connected may be better than a big mean cable with a milspec terminal clamp improperly connected.
"Good enough" is frequently good enough. The parts house cable is readily available and easily installed with no special tools. The demands of the CUCV are relatively modest in the scheme of things. The original CUCV cables were spec to be able to slave start vehicles with much higher amperage draw than anything on board the CUCV.
ezgn
1,039
Lake Elsinore Ca.
The "see also" part is the positive terminal. These terminals will carry more amperage. This picture doesn't really show how much more "beefy" than the standard commercial part is...
Buy a Temco Hammer Battery Crimping Tool on Amazon For $20 bucks. It crimps from 8 AWG up to 4/0 AWG. Buy the 3/8'' copper lug rings and the right size lugs for the size wire your using, it is a very basic job that you will enjoy doing.
chucky
18,858
TN .
On these type here beware there are some that look like these on amazon and ebay but have to much aloy or something in them they dont rap around the post when tighting them the ear that has the N or P on it just snaps off /breaks rite in the ear they dont have enough lead in them to bend and for those that dont know your positive post and neg post are 2 different sises so pay attention to the lug and the post when putting new lugs on your batteries .
WWRD99
1,647
York Pa
I found those at a surplus store north of Harrisburg Pa a few months ago...they had the positive and negative sizes and got 8...I think the were under 5$ each too...fit perfect.
MarcusOReallyus
815
Virginia
Have one made by BestBoatWire.com. Excellent quality made to spec. Choose your length, gauge, and ends. I like to get it with the clear heat shrink so I can monitor what's going on under there. Use military terminals and you are good to go.
98G
Former SSG
4,268
