Anyone know what this is?
Seth_O
Sac CA
I picked this up while in UT two weeks ago. Unfortunately no data plate on it anywhere. Can anyone identify what the frame is from?
I did a quick search on google and can't find anything with this 'axle' and p-brake setup.
Also, anyone know where I can get a 2.5" 8pt socket to disassemble the hub's? Found one place, but they wanted $109 :|.
Lieutenant
57
Michigan
Are you sure it's a 2-1/2"? OTC makes a 2-9/16" 8pt, part number 1905. Should be less than $20
Seth_O
Sac CA
Negative.
It's military. It's the chassis used on the later type lube units. As well I'm sure it is used in other configurations. Not counting the ball hitch....that's custom.
Westfolk: tks for the insight, any idea what the type could be (i.e. M1416m 1101, etc)? I can go do further research if you can point me in the right direction ;-). Sorry if it's a newbie question
319: I could be wrong, I got as close as I could with a tape measure. Not familiar with OTC?
319
Lieutenant
57
Michigan
Seth_O
Sac CA
Awesome - tks 319. Found it for $15 and placed an order. Best news I've had all day!
On a side note, where do you folks get replacement parts for these military trailers? This one has a rubber bushing that goes around the axle that's begging to be replaced.
Carter
Delta, Pa.
What size tires are on it? If they are 16", the wheels look like M101/ A1 trailer and M37/ B1 Budd style and you may be able to locate parts at one of the usual dealers.
