AO 3116 Fuel shut off solenoid part number
Having finally pin pointed my electrial issue to the failed fuel shut off solenoid, I am having trouble finding a part number for it.
Looking in the parts index, the breakdown on the fuel system shows the solenoid, but there is no listing given for it as a part separate from the governor.
I know it is definitely available as a separate part, I just want to make sure I am ordering the one suitable for this application.
Anyone have any direct knowledge?
Ronmar
7,403
Port angeles wa
The 24P manual(found up in the manuals section) will have most of the parts and exploded diagrams for the A0 and 3116. For engine specific parts, you can also go to parts.cat.com and enter your engine s/n and search up parts specific to your build. For instance if you then search for “governor” under your 3116 engine S/N it will show you the governor that was included with your engine build. If you click on it you can then find the available sub assemblies, like the run solenoid or the lift pump cartridge and seals…
