APC tow points/shackles
Artisan
227
CDA Idaho
Guys can someone school me on the exact name for this type of
clevis towing connector that Derrick has for sale?
I am told that are for connecting to cables as pictured HERE and HERE
Slang names OK but an exact name of that type of connection is perfered.
TIA!
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I don't have the name to help, but a little info to add, as it might not be known.
The wire ropes have an oblong connector on their ends. It slides over that tow hook sideways and won't come off while pulling. They are very handy. I ended up with some to use with my wrecker. Not sure if this was common knowledge or not.
CARRY ON!
Artisan
227
CDA Idaho
Thanx Gimp, you say you ended up w/ "some", is that some as in "some" FS? ;-)
No promises but show me the goods if so and I will keep it in mind,
if you have a minute SIR. ;-)
It sounds like you have something I have not seen actually...
gimpyrobb
27,786
755
Cincy Ohio
None available, sorry. They were all over a couple years ago. I'm kinda surprised they aren't more popular.
M813rc
3,205
Near Austin, Texas
And yes, they do fit on the same brackets the usual deuce/5-ton/etc. have for the round clevises, using the same pins.
Cheers
