Applied Companies ECU
markland556
Seattle, WA
Working on trying to get my 10 ton Applied ECU up and running again. Was looking to see if anyone may have a TM laying around.
The unit is from 06, had her running a few years back, but its time to sort out some issues.
NSN: 5895-01-532-5326
19,673
Not certain that I am on the right track, but a Web search for the NSN and "Technical Manual" pulled up an Interrogator Set and Antenna-Radome
The link I found is below.
Poccur
134
Roanoke, VA
That NSN points to part number 4191-120 which is the right format for Applied Companies....My Applied 10 ton manual is for 53005-120...
You are welcome to a copy if you want. It might be a simple cabinet change or one is horizontal vs vertical...
