APU unit in Deuce
jw4x4
Dayton, Ohio
Used units are $2500-3k. You may be able to find a beat up one for less. They are tailored towards over-the-road trucks, to lower operating costs by running off the APU when parked, thus being able to shut off the truck's engine. There are ever increasing laws concerning trucks sitting at idle.
m-35tom
221
eldersburg maryland
so it's just a generator running an 120 vac a/c unit and a resistance heater and if you need, a block heater. whan do you need this in a deuce?? i have a 20k fuel burning heater behind the shortened glove box, a/c run off the engine. if you need 120 ac, how much do you need? too bad the old onan rv gensets are not usually diesel.
tom
bones1
Southern Maryland
"too bad the old onan rv gensets are not usually diesel." I look for the diesel Onans, Perkins all the time, best stuff you can buy. I have removed my spare tire carrier on the Deuce and would like to find a diesel generator, 5k or better, to fit in that spot. This would be good http://en.visonerv.com/cgi-bin/md/M11455/s1.pl? Iknow folks have done this but I thought the APU's were interesting.
A bunch of used APUs here
http://www.nexttruckonline.com/part...nerators+|+APUs/Other/All-Models/results.html
These are water cooled so the heat is derived from the small engine temperature. I suppose the idea is to have a/c ,heat and 120v completely independent of the truck.
