MN arctic heater parts
blackhueys
-11
mn
I have the following parts, you can also look at this link with the manual https://www.steelsoldiers.com/threads/cucv-gm-instructions-for-winterization-kit.220290/ to find your part If I dont have it listed ask and tell me the part number from the book as I might have it let me know
118806 tee
144130 elbow
444476 elbow
140642 tee two way
118749 fitting
443998 connector
110200 connector
11502835 screw
356128 clip
9441638 snap
14072347 switch
343449 clip
14004512 clip
8917260 clip
9409754 gasket
340815 clip
14074469 bracket
15599236 clip
14074454 sensor
15599972 switch
3738198 plug
11501012 screw
3977775 retainer
9422273 nut
423532 screw
14061352 clamp
1476237 wire assy
3838094 nipple
14074487 clamp
11503550 screw
11503978 washer
381700 nut
11500190 washer
343444 clip
9419274 washer
9440926 screw
187119 washer
11502835 screw
14063366 reinforcement
272244 o ring
14074487 clamp
15599920 spacer
15599237 coupling
15599238 coupling
14074477 gasket
14072372 pipe
fuel pumps
14074474
14072368 hose
15599217 clamp
15599200 pipe
14076270 gasket
14063367 turn button
14022683 seal
15599275 clip
3723225 grommet
14028916 gasket
7717066 spring
10005327 fitting
14028951 gasket
15599246 bracket
15599245 bracket
9440173 valve
9409761 cap
14074459
bracket to mount control box to dash
1404470
1407447
14074458
14074465
14072373 filter
