Are all the well nuts on the fuel tank the same size?
Light in the Dark
5,894
MA
dav5
183
Mono, Ontario
The side well nut is the same as the top well nut if you look at the TMs.
Tank Depot charged a ridiculous shipping fee per unit and didn't reduce it if you bought more than one. Apparently if you call them you might talk them in to discounting the shipping for multiple units.
2Pbfeet
758
Mt. Hamilton, CA
Also here
Shipping was a little more reasonable and it comes with washers / o-rings. Easy to replace and the flats on the threaded portion make this version any easy and quick swap. (Thread a wire (hanger, whatever) from the fitting hole out the filler neck, use the wire to pull the fitting in place, tighten, and the retrieve the wire through the filler neck. Takes a couple of minutes.)
All the best,
2Pbfeet
