Are slave ports rebuildable
Crawdaddy
Louisiana
Are the 2-pin slave ports rebuildable? I need to replace the cables coming out of the back of the slave port with longer cables to reach now that I'm running non-stock batteries on my MEP-016b genset. I haven't pulled it out of its bracket yet, but was hoping someone knew off-hand.
1,172
Some are and some are not.
You will need to look at what you have.
You could always connect at the end terminals and extend what you have.
Crawdaddy
Louisiana
Thanks for the info. I'll have to pull it out and see. It would be a shame to have to extend the cables since they only need another 6 inches max to get where I need them to be.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
2pin should be. I have DE-soldered original leads and put on new ones. Make sure you use PPE when you heat up and pull out the old cables, there is a lot of solder in there!
NDT
6,145
Camp Wood/LC, TX
Yes, the pins press out of the rubber insert. (not easily) Ditto on gimp's warning, I remember using a propane torch to heat the pin.
gimpyrobb
27,785
748
Cincy Ohio
Yup, propane or mapp gas. Spray the housing with a ton of silicone spray lube and punch the pin out of the housing is the best way I have found.
Crazyguyla
124
Altus, OK
I have the new cables soldered to the pins. I can't get the pins back into the rubber bushing? I had one almost all the way in, the other i can only manage halfway in.
Welder1
156
Albany Ga
I find if you use silicon dielectric grease you can get things thru rubber much easier. It’s avalable at auto parts store. Try that and see if that works.
