Are the dip stick accurate on ECV trucks ?
HUMMER H1
820
California
I bought an ECV humvee that was sold as not runner,
I started today and runs beautifully.
However transmission doesn’t engage unless I raise the Rpm to 2000 ish
all the symptoms show no fluid, transmission pan bolts were taken off ( I assume to drain the fluid)
but the dip stick shows a little over than normal X mark,
is it possible the dip stick is not accurate?
later model 4L80e transmissions don’t have a drain plug I can’t drain and start all over,
thank you
Eric
TOBASH
3,475
Brooklyn, NY
1-“dip stick” not always accurate on hand built trucks.
2-drop the pan, catch the fluid, and reseal with NEW FILTER.
3-I will look for tranny troubleshooting guide.
Edit - Mogman posted below but I will post here also… https://www.steelsoldiers.com/threads/new-humvee-owner-transmission-question.216108/#post-2528478
4- I told you on the phone that this is exactly what my M1165 did, so we added fluid and that fixed it. Overfilling can cause problems and damage though.
Engine sounds awesome!
HUMMER H1
820
California
1-“dip stick”.
2-drip the pan, catch the fluid, and reseal with NEW FILTER.
4- I told you on the phone that this is exactly what my M1265 did, so we added fluid and that fixed it.
drop the pan and drip 😂😂
I guess since I don’t know how much ATF is in the transmission, I have. I choice but to stop the pan and start over again, at that time I’ll also add drain plug.
TOBASH
3,475
Brooklyn, NY
Mogman beat me to posting 👍. Nice work Mog.
thompsoncustom
106
iowa
the guys on here were really helpful when my tranny was acting funny.
have you tired using a jumper wire and seeing if there are any tranny codes?
TOBASH
3,475
Brooklyn, NY
Eric has forgotten to update. 🙄🙄🙄
Fluid was checked with truck running.
Eric dropped the tranny fluid pan and tranny only had a couple of quarts in it. Dip stick was very innacutate.
Eric refilled with correct volume and tranny shifts properly.
I don’t mean to steal his thunder. I just thought you all deserved an answer to all outstanding questions. He and I talk daily.
HUMMER H1
820
California
thank you Charles
so yes dipstick showed normal operating level however transmission only had 3qts of ATF in there,
And because those transmissions don’t have drain plug, I had no choice but to remove then pan to drain everything and start all over again,
With the large transmission cooler of ECV
It takes about 4 gallons of dextron 3 to get the transmission working again. Dipstick is not accurate in ECV humvees, now I check the level and it shows well about the X mark,
In fact I compared that to my other running M1152 and that also shows well above X mark.
first washIMG_8022.jpegIMG_8011.jpeg73082968525__5451C029-2B8F-438E-8503-188D46233E1C.jpeg
Retiredwarhorses
4,177
Brentwood, Calif
Calibrate the dip stick? Not accurate?
I service maybe 2 Transmissions per week…all turbo and NA 4 speed trucks, never has a transmission taken 4 gallons of ATF.
it takes quite a bit of time to fill properly, it cannot be rushed, you get a false reading on the dipstick from fluid still in in the filler neck, also engine must be running in park and shifted through all gears, pay attention to the hatch mark side of the stick, not the smooth side.
Dry 13.5 qt (12.8 L)
Drain & Refill 7.7 qt (7.3 L)
HUMMER H1
820
California
14 qt is 3 gallons
if it seats longer period eventually big ECV trans cooler also drains into the pan.
to refill everything back up is 3.9 gallons to be exact
Retiredwarhorses
4,177
Brentwood, Calif
tomelroy
66
Morgan, UT
Confirming that the dip stick is measuring the correct depth of fluid in the pan should be ruled out. If everything else is done right, maybe somebody swapped out the dip stick from something else or ??? 99+ percent it was correct off the line. Only way to rule this out is droop the pan and make sure it is correct. If it is correct I would assume I am doing something wrong in my check procedure.
