Are these variable rate or only HD?
erasedhammer
59
Maryland
I noticed that I have the cast upper perches and when I've had 2500 lbs of gravel in the back the springs didn't budge.
Do I have the normal 3000 lb HD springs or variable rate?
They seem extremely stiff and I want to have the normal HD ones so I can upgrade to variable rate for the softer ride.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Since there is thicker rings and thinner rings, I would say variable, but I don't play with these trucks so I may be wrong.
