- 34,012
- 1,808
- 113
- GA Mountains
So quite some time ago I installed some armor headlights on the back and sides of my deuce. Today I wired the side lights in with the back lights. All 4 lights are powered from the same wire. My problem is the left side light is blowing bulbs within about 10 seconds. Can't be getting more voltage than the other lights, they are all powered off the same wire. I even swapped housings. Can an insufficient ground be the problem? I'm befuddled. Footnote, when the low beam burned out I switched to the high beam and burnt it too.
