asbestos danger?
rickta24
Dallas, Texas
was reading through the engine manual. it said some gaskets contain asbestos? have i also heard that CARC contains asbestos? how dangerous is it on the CUCV?
ida34
32
Dexter, MI
Asbestos in vehicles is not just limited to the cucv. Brakes and clutches contain asbestos as well. The military puts all kinds in information in there to scare you. Did you know that night sights on firearms are radioactive? They are but they will not kill you. The small amount of asbestos exposure you get from the gaskets will not kill you either. If you are grinding the gasket away I would wear a respirator or if you are working on the brakes beware of the dust. Wear a respirator and do not blow the dust off with air. Use brake clean to clean it off.
t4billl
Orlando
abestos only effects you if are exposed to it on a prolonged basis, it however will increase your chances for cancer along with breathing 2nd hand smoke or prolonged exposure to deisel fuel
ARMYMAN30YearsPlus
Parkville, MD
I worked for a plumber in the 70's and used to have the job of coating the new furnaces with asbestos. I made heat sheilding for my headers out of asbestos cloth for quite a few cars and trucks. My old house in Massachucettes has asbestos siding. I would rather have the asbestos around than burn down. Also a note for many years our barrel mits for the M-60 machine gun were asbestos as well as school shop safety blankets. I still run and in pretty good shape for a 53 year old dude and the stuff never hurt me only kept me from getting burnt.
ida34
32
Dexter, MI
I had a shop teacher die from lung cancer from asbestos exposure over the years. I would rather be safe then have it accumulating in my lungs. I also use the respirator when spraying paint. I use it pretty often.
ARMYMAN30YearsPlus
Parkville, MD
When I taught shop they still had the asbestos fire blankets and as soon as you opened the cover you could see the asbestos fibers in the air. I always wore at least a paper filter if I got near them. I did use a couple of them to wrap headers but I soaked them in high temp cement first and then wrapped them thus no fibers could be seen when I hand wrapped them. It does a great job on headers. I am quite sure my time in the Coast Guard in the early 70's exposed me to more asbestos than any where else. All but one of the Cutters I served on were build during WW II.
TigerHawk
Small Town USA
The top on my M35A2 has some kind of nasty looking insulation on the top and I was wondering if this was asbestos? Around the sides of the cab is closed cell foam insulation but the stuff on the inside of the top is different! Any thoughts?:?:
2,413
Bring that truck by the "Hooch" and leave it Tiger.:!:
We will study, probe, test and otherwise evaluate said top.
Should be ready for return some time in 2012:roll:
