Asking this for Dave P he is on the road..
citizensoldier
Northern Michigan. Smelt City
Adition from Dave
He says the inspection hole is very small and there is a crossmember in the way so he can not tell. He has the cummins engine in this tractor if that changes things too. Any info on swapping pressure plates and cluches would help him. He has a 5 ton dump multifuel, and a 5 ton gasser for parts truck but needs to know if they are the same.
Knucklehead
Spencer, MA
RE: Adition from Dave
All the pre 900 series 5tons used a 15" spicer clutch assembly. I went into my shop and double checked. I have two complete clutch assemblies, one off a gasser and one MF. They are indenticle. I know the MF will change with the Mack and Cummins. I hope this helps.
