stanzuray
- 26
- 18
Last night needed to get towed home. One minute I parked all well and when tried to move again the transmission will not go into any gear. Revving engine does not help as with burnt bands. Fluid looks new and linkage is moving fine. Some things that may mean something are it goes into park and holds fine. Also I keep fluid right at correct level (checked when running) but dipstick reads slightly high when not running. However when started now and checked, reading stays at slightly high and is exact level as when not running which it never did I think. Planning to pull pan when I get a new filter in (old one is new really) but thought I'd check with anyone whose a tranny expert or had this problem. Thank you. Stan
