Aux air tank on 1083 ????
chucky
18,961
TN .
Does anyone know if i can remove all the plumbing coming out of the side of the 3rd {rear} air tank and plug off all the holes and lines that go to it ? My ctis doesnt work anyway and i didnt know what functions i might lose by doing this?
Andyrv6av8r
457
Spartanburg,SC
Well....
That's your wet tank from the drier. You have to have it to feed the other 2 tanks and have brakes....so I wouldn't cap it off.
If your CTIS doesn't work why are you worried about this tank?
chucky
18,961
TN .
Im just talking the line coming out under the slave cable port with the diaphram in it and the electric port from the ctis not the lines in the back of the tank
Andyrv6av8r
457
Spartanburg,SC
Again, why do you want to remove it because of non-functional CTIS? It feeds your cab airbags also.
chucky
18,961
TN .
Well....
I wanted to get rid of that one big whatever it is running down the side of the tank because of storage box mounted right up against the battery box i could cut of the box to go over this thing but i didnt want to if ididnt have to i have it off now and caped but i could put it back on if im loseing something important ive run the truck no leaks ,the fan still turns i wasnt sure where the air comes from that locks differential center chunk in and out?
Andyrv6av8r
457
Spartanburg,SC
Your fan is engaged because of no air to the clutch. It will never disengage because you removed the air supply. Are you sure that you want that? I believe the differential lock is supplied by that air also.
Andyrv6av8r
457
Spartanburg,SC
Push come to shove you could tee into one of the other lines on the tank and cap that opening off. That diaphragm thingy is your PPV valve. It shuts off around 75 psi to conserve air to your other 2 tanks, hence, the brakes.
chucky
18,961
TN .
Damit i was hoping to be done with the ppv but guess not ! sounds like its too much colateral tied to this thing i droped the thing to mount these side boxes but i can go back inside the box and put it all back original just leave the ctis unpluged thanks for the knowledge back to the srawing board
