We acquired a mil flat 4 cyl. gas engine (looks like Lycoming culinders) that we are going to use as a water pump engine. On trying to start the engine the starter engages but continues to run after the switch is turned off. The starter when removed operates normally (disengages when switch is turned off). When reinstalled it continued to run again. We tested the attached solenoid with battery removed from the starter and the solenoid seems to engage & disengage normally even when mounted to the engine. We are mystified why the starter stays engaged & running with no power to the solenoid switch side!
Any ideas? Oh yes, this engine was new in the box when we got it. I have no id # for it but will attach pictures tomorrow. Thanks
