chartley04
- 0
- 1
- Illinois
Got a 2003 LMTV with a no crank problem. After going through everything, the problem seems to be the supply voltage coming into the aux starter solenoid isn't there. When the starter button is pressed, I got the signal voltage, and the solenoid closes like it should. I have verified the signal power from button coming into it and that the contact is indeed closing. Pretty new to working on a LMTV as it is for the fire dept I'm with. My question that I haven't found a clear answer on is where the supply voltage for the aux starter solenoid comes from? The few wiring diagrams I have manage to find makes it appear that it comes from the main power supply on the starter? I have been able to use a jumper wire to activate the starter solenoid and get it to fire but want to fix it the proper way if possible. Thanks for all the help and I apologize if this has been covered before, I did try searching but did not find the answer I'm looking for.
