Auxilary Plug
willysmd
KENT. UK
Hi
Just obtained one of them auxilary plugs for the Reo to fit the socket on the side, question is how does the bloody thing come apart so I can wire it up??
please
willysmd
KENT. UK
No pics Im afraid, it is 2 pin that fits in the socket on the truck, there are two different diameters about 3" across o one with the pins and the othere is slightly smaller and has a hole for the cable with grips in to stop pulling cable out, thats it.
DDoyle
80
West Tennessee
Mark,
Are you referring to the outlet on the interior of the truck? If so, a breakdown is in the ORD 9 for the 5 ton wrecker - maybe in the -20 or -30 as well (I tend to use 1950s era books rather than the later ones.)
Or are you referring to the slave receptacle that is on the outside of the truck? (or the plug that inserts into it?)
Just saw your second post - so I presume we are discussing the slaving apparatus. I've had the plug apart on one of mine - but I don't remember the details. I should be home later today and hence able to look at it.
Best,
David
