awsome tires for bobbing
SR71BLACKBIRD
Galion, Ohio
At gl in columbus and saw 4 awsome tires for bobbing the deuce. Problem is they in tall stack in shrinkwrap on pallet and do not know size.
I want to go singles but not taller than stock if possible. Can this be done cheap?
avengeusa
MI USA
if you want to do singles, and cheap, just do what a lot of the guys here have done, flip the rear hubs and use the wheels/tires you have
but we have no idea what tires you are looking at
SR71BLACKBIRD
Galion, Ohio
jpcj Let me know how they work. I actually wanted them but did not know the size I needed. I actually made this post thinking somone knew what they were but got no luck with that.
sixfeathers
Banned
68
Baltimore/Maryland
If you bob your truck? do you have to change the title weight and change plates?..because then you have mutilated truck. that is considered a hot rod then..at least here in MD..
11Echo
92
CT W. R.
I had bid on those tires also. I didn't go very high because I didn't know the size.
bigearslgc
london, ky.
C & C equipment, unionville, in. phone#812 322 4907, ask for clint chitwood. he has the best tire prices i have found, $600 for 46in. $600 for 53in. tell him bigears from kentucky sent ya. i just bought a set of 46x15.5x20 XL's from him.
JasonS
131
Eastern SD
It is no big deal to change the weight or plates. I've even legally changed the year of a vehicle. The DOT doesn't care if you remove axles; they do, however care if you ADD axles.
jpcj-7
Shiloh, Ohio
you get those big tires?
Well in typical GL fashion what I thought I was bidding on was nothing like what I got! I got four HMMWV tires on rims, one 9.00-20 NDCC on a rim (will make a good spare!) and a 22.5 Michelin steer tire on a rim, God only knows what it came off of!
